[mapserver-users] intersect
jef.mony at free.fr
jef.mony at free.fr
Thu Aug 22 04:43:09 EDT 2002
I noticed a little problem with the intersects function of the ShapeObj.
I have two Shapes : a polygon and a point
$line = ms_newLineObj();
$line->addXY($Xmin,$Ymax);
$line->addXY($Xmax,$Ymax);
$line->addXY($Xmax,$Ymin);
$line->addXY($Xmin,$Ymin);
$poly = ms_newShapeObj(MS_SHAPE_POLYGON);
$poly->add($line);
$line2 = ms_newLineObj();
$line2->addXY($Xmin,$Ymax);
$poly2 = ms_newShapeObj(MS_SHAPE_POINT);
$poly2->add($line2);
If I try $poly->intersects($poly2) I have a wrong result, in fact it's like I
would have test the intersection between the pôint and the boundaries of
the poly ...
but If I use $poly2->contains($pt) with pt a point with the same coords that
the poly2 it's work fine ...
An idea, is it a bug or a wrong use ?
Thanks
