[mapserver-users] configure problems
Ken Kyler
ken at kyler.com
Thu Aug 22 14:17:07 EDT 2002
First problem solved. After reading configure.in, I found this
test -f $GD_DIR/include/gd.h && GD_INCLUDE="$GD_DIR/include"
I don't know why they ask for the GD directory and then append the /include/
subdirectory to it. Doesn't make sense.
Anyway, it works fine with
--with-gd=/usr/local
instead of
--with-gd=/usr/local/include
now on to the next problem
!!! The current version of PHP MapScript requires PHP4 configured as !!!
!!! a CGI and cannot be used with PHP4 configured as an Apache module,!!!
yet the Mapscript FAQ says
"2.3 Does MapScript require that PHP3/PHP4 be a DSO?
It does not, it will work either way.
However, if PHP was compiled as a DSO then you will have to pass
the --with-apxs switch to the Maperver configure script. It is very
important that the --with-apxs switch be provided if PHP was compiled as an
Apache DSO, especially on systems like RedHat 6.2 where Apache comes
compiled with the -DEAPI switch and this has an impact on DSO modules."
<sigh> Please pass the Ibuprofen...
Ken
