[mapserver-users] confusion about postgis bounding box -> valid map extent
Alex Rice
alex_rice at arc.to
Fri Aug 23 14:46:06 EDT 2002
I am using PostGIS and getting a bounding box of objects in
PostGIS with the functions Envelope() or Box3d(). The bounding
box will not be the same aspect ratio as my Map object.
Here are some things I am confused about.
- Is it correct that in Perl mapscript, the only way to set the
extent of the map object is directly accessing
$mapObj->{extent}->{minx} etc.? Pretty sure this is true, just
want to verify I'm not missing something.
- What's the expected behavior if in Perl mapscript I set the
extent as above, call prepareQuery(), then draw, if the new
extent has a different aspect ratio than the output image size?
- In php_mapscript.c there are functions for dealing with the
map extent based on a box inside the visible image, or a point +
scale, etc. Does anyone have example Perl code, for instance, of
the map->zoomRectange() function in php_mapscript.c? I have seen
the &set_extent() method from mapquakes.pl and seen the examples
Lowell posted in Perl, but those are zoom & pan, not fitting an
extent to another rect. If there isn't sample perl code
- In maptemplate.c, the function setExtent() has several cases
for the "source" of the change in extent. Do any of those cases
apply to my situation? Maybe I can adapt the C code to a Perl
method.
- Is there a way to get PostGIS to fit a bounding box to an
aspect ratio? It would be nice if I didn't have to do it in perl
at all. A function like this is what I'm imagining
select extent2extent(5, 3, box3d(the_geom), centroid(the_geom));
where 5:3 is the aspect ratio
box3d is the extent of the object
centroid is the center of the requested new extent
Thanks,
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
