[mapserver-users] confusion about postgis bounding box -> val
id map extent
Puneet Kishor
pkishor at GeoAnalytics.com
Fri Aug 23 15:23:24 EDT 2002
> - In php_mapscript.c there are functions for dealing with the
> map extent based on a box inside the visible image, or a point +
> scale, etc. Does anyone have example Perl code, for instance, of
> the map->zoomRectange() function in php_mapscript.c? I have seen
> the &set_extent() method from mapquakes.pl and seen the examples
> Lowell posted in Perl, but those are zoom & pan, not fitting an
> extent to another rect. If there isn't sample perl code
Is this what you might want...
# calculate cellsize in x and y directions.
# cellsize is the geographic size of
# each pixel on the screen
$cx = ($g_maxx - $g_minx) / ($mapObj->{width});
$cy = ($g_maxy - $g_miny) / ($mapObj->{height});
# (p_minx, p_miny) (p_maxx, p_maxy) are your direction
# corrected screen lower left and upper right box coords
$x1 = $g_minx + ($cx * $p_minx);
$y1 = $g_miny + ($cy * $p_miny);
$x2 = $g_minx + ($cx * $p_maxx);
$y2 = $g_miny + ($cy * $p_maxy);
$g_minx = $mapObj->{extent}->{minx} = $x1;
$g_miny = $mapObj->{extent}->{miny} = $y1;
$g_maxx = $mapObj->{extent}->{maxx} = $x2;
$g_maxy = $mapObj->{extent}->{maxy} = $y2;
