[mapserver-users] rendering world data
woodbri at swoodbridge.com
Sun Aug 25 17:14:34 EDT 2002
Chris,
Are you using shapefiles? Assuming it is in shapefiles:
How did you get the vmap0 data into shapefile?
I wrote a program that can tile shapefiles into smaller shapefiles.
It should be pretty east to modify it split polygons at 180 degrees
into multiple polygons.
See http://swoodbridge.com/tools/ if you are interested in trying to
modify shp2tile to split polygons.
-Steve
On 25 Aug 2002 at 16:05, Chris Stuber wrote:
> mapserver-users,
> I've trying to render world data (vmap0), with a mercator
> projection, and am running into a problem with the USSR polygon
> getting messed up, I guess because it extends past the international
> dateline at 180 degrees. It is rendering with horizontal lines with a
> sort of inverted effect. Seems to render fine with ArcView, etc...
> but so far no luck with mapserver. Anyone had any experience with
> this type of problem??
> Thanks,
> Chris Stuber
