[mapserver-users] Make points Transparent?
Eric L. Blevins
eblevins at insight.rr.com
Sun Aug 25 16:23:49 EDT 2002
Here is my layer that puts some points in the map.
Is there any way to make the points somewhat transparent so you can see things behind them?
Sometimes there are so many points in an area they completely cover previous layers and I would like to make the points somewhat "see-through" so I can see the layers underneath.
LAYER NAME signal
TYPE POINT
STATUS off
DATA "nettry/signalwepoff"
maxscale 15000
CLASS
EXPRESSION ([SIGNAL] <= 100 && [SIGNAL] > 70)
NAME "Open - Signal Strong"
SYMBOL "circle"
SIZE 8
COLOR 100 0 0
END
CLASS
EXPRESSION ([SIGNAL] <= 70 && [SIGNAL] > 60)
NAME "Open - Signal medium"
SYMBOL "circle"
SIZE 8
COLOR 150 0 0
END
CLASS
EXPRESSION ([SIGNAL] <= 60 && [SIGNAL] > 40)
NAME "Open - Signal low"
SYMBOL "circle"
SIZE 8
COLOR 200 0 0
END
CLASS
EXPRESSION ([SIGNAL] <= 40 && [SIGNAL] >= 0)
NAME "Open - Signal weak"
SYMBOL "circle"
SIZE 8
COLOR 255 0 0
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020825/4220287c/attachment.html
