[mapserver-users] confusion about postgis bounding box ->
valid map extent
Steve Lime
steve.lime at dnr.state.mn.us
Mon Aug 26 10:36:58 EDT 2002
It always centers the old extent and gaurantees that the entire old extent is contained in the new one.
You can nab the javascript at:
http://maps.dnr.state.mn.us/javascript/mapserv3.6.js
There a several little zooming methods in that code. Let me know if you have questions.
Steve
>>> Alex Rice <alex_rice at arc.to> 08/23/02 05:33PM >>>
On Friday, August 23, 2002, at 01:27 PM, Steve Lime wrote:
> In the C code the extent will be adjusted for output image size.
Does it try to center the old extent in the new extent, or does
it do clipping and shifting?
> I've got all those written in C and javascript. Let me know what
> you'd like
> to see. Otherwise MapScript already has a method to fit a rectangle to
> a new window size. It's part of the rectObj class (of which
> extent is one)
> and is called fit. For example:
> $cellsize = $map->{extent}->fit($newwidth, $newheight);
I would love to see any javascript functions you have. It's a bit
easier to read then C for me.
> Already addressed in a generic way with the fit method.
OK I see. I guess what I am looking for is a way to do what the
zoomScale() php function does, except I will be starting with
georef coordinates not pixel coordinates.
Maybe after seeing some of your code it will all "click" for me!
Thanks,
Alex Rice <alex at mindlube.com>
Mindlube Software
http://www.mindlube.com/
