[mapserver-users] Reference Map
E Perik
erwin at perik.nu
Mon Aug 26 16:56:28 EDT 2002
just change your original map-file settings to be used for your
reference-map-image.
--> make copy of your original map-file, and change
1) Size
2) Layers (on/off)
Then let that one run by mapserver and get the image from your
temp-folder.
I'm sure there are other options, but this one is easy to do and you
basically need to do it once in a while,...so,.... :)
Me.
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of EDUARDO
PATTO KANEGAE
Sent: maandag 26 augustus 2002 20:50
To: MapServer USERS (Correio eletrônico)
Subject: [mapserver-users] Reference Map
how could i create a reference map for shapefiles, for using with
mapfiles?
Eduardo Patto Kanegae
eduardopk at vcp.com.br <mailto:eduardopk at vcp.com.br>
Time Planejamento - UNIDADE LA - Ramal 9126
eduardo at scopotecnologia.com.br <mailto:eduardo at scopotecnologia.com.br>
http://www.scopotecnologia.com.br <http://www.scopotecnologia.com.br>
