[mapserver-users] Symbol error with Mapserver and Debian
Gleydson Mazioli da Silva
gleydson.mazioli at ima.sp.gov.br
Tue Aug 27 13:15:34 EDT 2002
Thanks,
That change solved my problem :-)
Daniel Morissette <morissette at dmsolutions.ca> em Fri, 23 Aug 2002 16:09:53 -0400 escreveu:
> In your init page, you have the following hidden parameters with NO
> VALUE:
> <INPUT type=hidden name=map_nomemunicp_class_expression> <INPUT
> type=hidden name=map_nomespcampst_class_expression>
> For some reason, Netscape seems to pass them in the URL as
> map_nomemunicp_class_expression=++
> setting the value to 2 spaces and that's what confuses MapServer's
> expression parser.
> Removing the 2 spaces ("++") in the URL fixes the issue, so I would
> suggest setting the value explicitly in the init page using VALUE="" in
> the tags.
> Daniel
> Gleydson Mazioli da Silva wrote:
> > Hi all,
> > After upgrading my Debian system (libc6 and other packages, from memory), I got the following message
> > when I try to access the mapserver application:
> > getSymbol(): Symbol definition error. ():(1710)
> > The curiously is that the message only happens when accessed by Netscape Communicator 4.xx (IE, Mozillas and
> > other work fine). The page is available for Internet at address for bug reproducion:
> > http://www.ima.sp.gov.br/geo/ppi
> > Details:
> > Mapserver: 3.6.1 (also tryed with cvs release of mapserver, without sucess)
> > Libgd: 1.8.4
> > gdal: 1.1.7
> > Thanks in advanced for any help :-)
> > gleydson at ima.sp.gov.br
> > Consultor de Servidores GNU/Linux
> > IMA - Informática de Municipios Associados
> > Av. Anchieta 200 - Campinas - SP
> > (19) 3232-9611 - R. 216
