[mapserver-users] Symbol error with Mapserver and Debian
Daniel Morissette
morissette at dmsolutions.ca
Fri Aug 23 16:09:53 EDT 2002
In your init page, you have the following hidden parameters with NO
VALUE:
<INPUT type=hidden name=map_nomemunicp_class_expression> <INPUT
type=hidden name=map_nomespcampst_class_expression>
For some reason, Netscape seems to pass them in the URL as
map_nomemunicp_class_expression=++
setting the value to 2 spaces and that's what confuses MapServer's
expression parser.
Removing the 2 spaces ("++") in the URL fixes the issue, so I would
suggest setting the value explicitly in the init page using VALUE="" in
the tags.
Daniel
Gleydson Mazioli da Silva wrote:
> Hi all,
> After upgrading my Debian system (libc6 and other packages, from memory), I got the following message
> when I try to access the mapserver application:
> getSymbol(): Symbol definition error. ():(1710)
> The curiously is that the message only happens when accessed by Netscape Communicator 4.xx (IE, Mozillas and
> other work fine). The page is available for Internet at address for bug reproducion:
> http://www.ima.sp.gov.br/geo/ppi
> Details:
> Mapserver: 3.6.1 (also tryed with cvs release of mapserver, without sucess)
> Libgd: 1.8.4
> gdal: 1.1.7
> Thanks in advanced for any help :-)
> gleydson at ima.sp.gov.br
> Consultor de Servidores GNU/Linux
> IMA - Informática de Municipios Associados
> Av. Anchieta 200 - Campinas - SP
> (19) 3232-9611 - R. 216
