[mapserver-users] PHP MapScript 3.6.x cgi/module
Thomas Haechler
thaechl at geo.unizh.ch
Wed Aug 28 11:56:45 EDT 2002
Thorsten,
As far as I can see, the cgi / module discussion is referring to the way
how PHP (not phpmapscript) is installed, i.e.:
- if the php document where you have the dl ("php_mapscript.so")
statement inside is processed by a php installed as cgi, everything is
working.
- if it is processed by php installed as an apache module, you will get
the following error:
"Fatal error: Due to thread-safety problems, php_mapscript cannot be
used as a 'apache' module. You will have to reconfigure your PHP as a
CGI to run this version of MapScript." (I just did that little test now)
By the way:
It is possible to install apache with both, php as a module and php as
cgi at the same time. in the httpd.conf file you then have to specify
which documents are processed by which php version (example:
filename.php -> module, filename.phtml -> cgi). like this you can use
the module version for all mapscript unrelated purposes.
hope this helps,
Thomy
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
