[mapserver-users] PHP MapScript 3.6.x cgi/module
Daniel Morissette
morissette at dmsolutions.ca
Wed Aug 28 12:04:48 EDT 2002
Thorsten,
ms_GetVersion will work even if PHP is not as a CGI.
The error about CGI mode was added in ms_newMapObj() since you can't do
much in MapScript without creating a mapObj. So if you try calling
ms_newMapObj() then you will see the error.
Daniel
Thorsten Fischer wrote:
> Hi list,
> I have it seen mentioned several times now: That I should not use PHP
> MapScript 3.6.x as a module; only the cgi version is supposed to work
> properly. Ok. In fact, it is said, that when loading 3.6.x as a php
> module, an error would occur. But interestingly, on my installation(s) i
> can do the following:
> <?php
> dl ("php_mapscript.so");
> echo "<p>" . ms_GetVersion () . "</p>";
> And get output as this:
> MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=GDAL INPUT=SHAPEFILE
> Just wondering if i missed something. I do not use this in production (I
> obey to developers' orders) and know i might break something - these
> things are for my development and personal use. Just wanted to point out
> that the "there will be a warning" part isn't true. Nothing in my logs
> either, no matter how much verbosity or debugging noise i turn on.
> thorsten
> Thorsten Fischer thfischer at mapmedia.de
> MapMedia - Kartographie und raumbezogene Informationssysteme
> Am Borsigturm 42
> 13507 Berlin
> Deutschland
> http://www.mapmedia.de tel: +49 (0)30 43032102
