[mapserver-users] TRUETYPE not work
woodbri at swoodbridge.com
Thu Aug 29 22:31:52 EDT 2002
William,
Do you have a Map file Reference document?
You need to look at the LABEL section, you will see that it mentions
a FONT tag which references an item in a FONTSET. The document will
also tell you how to set up the FONTSET file which will need to point
to the the fonts on your system.
The documentation page can be found off the Mapserver home page.
-Steve
On 29 Aug 2002 at 22:04, Zhang, William wrote:
> Hi,
> I got error in the map file below. If I comment out TRUETYPE releated lines,
> the map file works. I downloaded the mapserv.exe from Windows Binary
> Download page, so it should be TRUETYPE enabled. Could somebody give me help
> on this one?
> NAME alm
> EXTENT -122.0837 37.6683 -122.1104 37.6885
> SIZE 800 600
> SHAPEPATH "C:\Inetpub\wwwroot\itasca\test\tutorial35"
> LAYER
> TYPE LINE
> STATUS DEFAULT
> DATA alm
> LABELITEM "FENAME"
> CLASS
> COLOR 255 0 0
> LABEL
> TYPE TRUETYPE
> ANTIALIAS
> COLOR 0 0 0
> ANGLE AUTO
> POSITION UC
> END
> END
> END
> END # end of map file
> Thanks,
> William Zhang
> Software Engineer
> C-Cor.net
> Phone: (925) 251-3019
> Fax: (925) 467-0600
> E-Mail: wzhang at c-cor.net
