[mapserver-users] Mapserver and Spatial Extent
James Anderson
james at danisat.net
Fri Aug 30 04:02:45 EDT 2002
I need to know more about the EXTENT command in a Mapserver map file. I
have a shape file layer of Kampala. The shapefile is in WGS 84 projection.
The center of the Shapefile is lat=32.5747819077374 and
lon=0.320786584028765 I need to know how to work out the Extent values
from the lat and lon. My map file looks like this
NAME EX1
EXTENT ???? ???? ???? ????
SIZE 600 600
SHAPEPATH "C:\Documents and Settings\Steed\My Documents\mapping\kampala\shp"
PROJECTION
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
LAYER
NAME "Kampala"
DATA kampala
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 250 175 25
END # end of class object
END # end of layer object
END # end of map file
If need to work out the values to put in by the ????s. I need some
formulas. When I put some random values in the extent, the mapserver
produces an image, yet it is plain white. I believe that this is because I
have the extent set to where there is no mapping data. I am still very new
to using this mapserver. I may have other errors in my map file. I need to
get this mapping to work. Can anyone help ??
Thanks,
James.
