[mapserver-users] strange data in shp file
Ed McNierney
ed at topozone.com
Fri Aug 30 23:21:38 EDT 2002
James -
It looks like the new SHP files are projected - probably in UTM or a
regional / state coordinate system. Unfortunately, there's nothing IN a
shapefile that tells you what projection it is. If there's a .PRJ file
with the same root name, that will give you info.
MapServer can reproject layers of any different coordinate systems onto
the same map. But you need to tell it what coordinate systems each SHP
file is in - otherwise it will assume they're all the same. In your
case, that means interpreting those numbers as lat/lon, which puts them
way out in hyperspace somewhere.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
-----Original Message-----
Sent: Friday, August 30, 2002 10:29 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] strange data in shp file
Hi there
I'm fairly new to using mapserver, and have hit a bit of a brick wall.
Up till now, all my data (which is in shp files) has worked beautifully.
if i run shpdump (from the shapelib pkg), then i can see all the coords
are in regular decimal latitude and longitudes.
However, some new data i received recently (again, this is in shp
format) doesn't seem to work. Mapserver doesn't complain, and displays a
map, but the layers that are using the new data cant be seen. When I ran
a shpdump on these new files, the coords range anywhere from 250 000 to
5 000 000 or so.
Is this normal? Or is the new data stuffed? Can I run the new data if i
only use shp files that use the same coords system?
any help would be much appreciated
james
"Before you criticise someone, you should walk a mile in their shoes.
That way, when you criticise them, you're a mile away and you have their
shoes. "
work: worker at aycs.org.au / personal: jimmy at deefa.com
msn: jimmy at deefa.com / ICQ: 6370237
web: www.deefa.com
