[mapserver-users] Draw points?
Frank Koormann
frank.koormann at intevation.de
Fri Feb 1 07:17:31 EST 2002
Hi Nacho,
* Nacho Benito (nachobenito75 at hotmail.com) [020201 12:56]:
> hello Frank
> Frank Koormann wrote:
> >* Nacho Benito (nachobenito75 at hotmail.com) [020131 23:18]:
> > > Hello everybody
> > > I would like to know if it?s possible to draw in the map a point what it
> > > isn't in any layer. In fact what I want to do is draw a symbol in any
> > > position.
> > > Please, could you help me? I've been looking for some information about
> > > that in the mailing archives list but I can't find anything.
> > > Is it relationated with symbols' object?
> > > Thanks in advance
> >iUsing the CGI-version this can be realised with an empty layer for
> >such markers in combination with the mapfile parameter changing methods.
> >http://mapserver.gis.umn.edu/doc/cgi-reference.html#mapfile
> >should give you an idea of the concept.
> Thank you for your help. Can you tell me how I could draw a point if I know
> the coordinates (however they could change). Do I have to do it with symbol
> object?
You need an empty layer defined in your map file:
(replace marker with something reasonable for your application,
especially select an existing symbol)
# Marker-Layer
LAYER
NAME marker
TYPE POINT
STATUS OFF
CLASS
NAME "marker"
SYMBOL "marker"
END
POSTLABELCACHE true
END
>From an URL you now can add points to this layer (for the next
visualisation) as indicated by
...&map_marker_feature=new&map_marker_feature_points=12345.6789+12345.6789...
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
