[mapserver-users] Draw points?
Nacho Benito
nachobenito75 at hotmail.com
Sat Feb 2 07:31:30 EST 2002
Hi Frank
Thank your for your help, It works now, I only have another little problem:
I can draw a cross symbol but it's too small, and it always have the same
size (and I zoom in it!)
What can I do?
In my map file I have:
SYMBOL
NAME "cross"
TYPE vector
POINTS
2 0
2 50
-99 -99
0 25
50 25
END
END
Thank you again
regards
Nacho
>From: Frank Koormann <frank.koormann at intevation.de>
>To: Nacho Benito <nachobenito75 at hotmail.com>
>CC: frank.koormann at intevation.de, mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] Draw points?
>Date: Fri, 1 Feb 2002 13:17:31 +0100
>Hi Nacho,
>* Nacho Benito (nachobenito75 at hotmail.com) [020201 12:56]:
> > hello Frank
> > Frank Koormann wrote:
> > >* Nacho Benito (nachobenito75 at hotmail.com) [020131 23:18]:
> > > > Hello everybody
> > > > I would like to know if it?s possible to draw in the map a point
>what it
> > > > isn't in any layer. In fact what I want to do is draw a symbol in
>any
> > > > position.
> > > > Please, could you help me? I've been looking for some information
>about
> > > > that in the mailing archives list but I can't find anything.
> > > > Is it relationated with symbols' object?
> > > > Thanks in advance
> > >iUsing the CGI-version this can be realised with an empty layer for
> > >such markers in combination with the mapfile parameter changing
>methods.
> > >http://mapserver.gis.umn.edu/doc/cgi-reference.html#mapfile
> > >should give you an idea of the concept.
> > Thank you for your help. Can you tell me how I could draw a point if I
>know
> > the coordinates (however they could change). Do I have to do it with
>symbol
> > object?
>You need an empty layer defined in your map file:
>(replace marker with something reasonable for your application,
>especially select an existing symbol)
># Marker-Layer
>LAYER
> NAME marker
> TYPE POINT
> STATUS OFF
> CLASS
> NAME "marker"
> SYMBOL "marker"
> END
> POSTLABELCACHE true
>END
>From an URL you now can add points to this layer (for the next
>visualisation) as indicated by
>...&map_marker_feature=new&map_marker_feature_points=12345.6789+12345.6789...
>Regards,
> Frank
> Professional Service around Free Software (http://intevation.net/)
> FreeGIS Project (http://freegis.org/)
_________________________________________________________________
MSN Photos es la manera más sencilla de compartir e imprimir sus fotos:
http://photos.latam.msn.com/Support/WorldWide.aspx
