[mapserver-users] MS3.5 for Win2K with Postgis
Pericles S. Nacionales
pnaciona at gis.umn.edu
Fri Feb 1 16:44:26 EST 2002
My mistake. I accidentally deleted the WMS line in the Makefile. I've
updated the package so please download again. It's at
http://128.101.73.155/projects/ms35_gdal_ogr_pg.zip.
-Perry
On Fri, 1 Feb 2002, Tyler Mitchell wrote:
> I'm just starting to scratch the surface of WMS, but in my opinion that
> error doesn't look it necessarily means WMS isn't compiled into the build,
> but perhaps the WMS server isn't setup properly? How do you know that
> everything is setup properly in your map file?
> Tyler
> "Andrew" <ahaigh at ic24.net>
> Sent by: To: "Pericles S. Nacionales" <pnaciona at gis.umn.edu>, "jrom"
> owner-mapserver-users at lists.g <jga at scot.cnes.fr>
> is.umn.edu cc: <mapserver-users at lists.gis.umn.edu>
> Fax to:
> Subject: Re: [mapserver-users] MS3.5 for Win2K with Postgis
> 02/01/2002 10:38 AM
> A quick question,
> according to the readme file in the zipfile, "This is the precompiled
> distribution of MapServer version 3.5 nightly build with
> GIF, OGR, GDAL, PostGIS (PostgreSQL) and OGC WMS server support."
> When I do mapserv -v
> I get:
> C:\mapserver>mapserv -v
> MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PR
> J SUPPORTS=TTF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> And when I try:
> http://plasma/cgi-bin/mapserv.exe?map=c:/demo.map&request=GetCapabilities
> I get the following output.
> mapserv(): Web application error. No template provided.
> I'm assuming that this version doesn't have WMS support, as stated in the
> README file. Is it possible to get hold of a copy which does?
> Thanks,
> Andrew
> ----- Original Message -----
> From: "Pericles S. Nacionales" <pnaciona at gis.umn.edu>
> To: "jrom" <jga at scot.cnes.fr>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, January 30, 2002 6:36 PM
> > Nicolas,
> > On Wed, 30 Jan 2002, jrom wrote:
> > > Perry,
> > > Thanx a lot for your reactivity !
> > > I tried the binaries you provided, It works on windows 2000 with
> postgis
> > Thanks! Good to know it works. I run into problems with mappostgis.c,
> > crapping out and giving the "BIG_ENDIAN/LITTLE_ENDIAN" error message. I
> > got around it by copying the Cygwin param.h header into MSVC's
> include/sys
> > directory and editing mappostgis.c. There might be another way to go
> > around this but it needs to be fixed permanently.
> > > Your mapserv.exe is much bigger than the one I compiled yesterday
> > > (680KB/2.4 Mb).
> > > I must have missed an important step in the compilation, or maybe the
> > > libpq.dll was not accessible from apache (mine was not in the
> > > winnt/system32 folder).
> > I compiled with static library support, except for zlib and libpq (hence
> > the need for the dlls). I tried linking GDAL/OGR and PROJ.4 libs
> > dynamically but I get lots of error messages.
> > > I'm interested in the compilation how-to on windows, though Linux is
> our
> > > prefered way to run mapserver and postgis.
> > There are already compilation how-to's for Unix (and Linux) and Windows
> > but I'll add the bit about compiling PostGIS support on Windows. Yup,
> > I'll add that to my ever expanding to-do list. :)
> > > Regards,
> > > Nicolas Ribot
> > > SCOT.
> > Ciao!
> > Perry N.
> > PS: Is you app available for public browsing? We ought to update the
> good
> > old MapServer gallery.
