[mapserver-users] Raster
Miroslav Sodja
Miroslav.Sodja at gov.si
Mon Feb 4 04:25:25 EST 2002
Hi all,
I have questions about raster data.
Layer with raster data has 38 images; images are about 4500 pixel width,
and 6000 pixel height with 2 colors. I have tile index of those images.
The problem is that every image has border with no data. And that border
goes across the data of neighbor image. The image should be transparent.
There is no problem if I have png file format with transparent
background and map file look like that
LAYER #raster 50.000
NAME "IME_50"
TILEINDEX "raster/ko_50.shp"
TILEITEM "PNG_NAME"
TYPE raster
STATUS ON
MAXSCALE 60000
CLASSITEM "[pixel]"
CLASS
EXPRESSION ([pixel] <1 )
COLOR 0 0 0
END
END
But response of IIS and MapServer in that case is very slow.
If I have tiff file format of those images I have white space around
every image in layer but response of IIS and MapServer is fast. Map file
is the same except:
TILEITEM "TIF_NAME"
I can't cut border with no data because images are deformed and new
world file would be difficult to calculate.
I have MapServer:
MapServer version 3.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
and IIS 5.0 on Windows 2000.
Thanks for any suggestions.
Miro Sodja miroslav.sodja at gov.si
