[mapserver-users] Joining ShapeFiles (FWD)
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 11 13:38:16 EST 2002
Tony,
You don't need to join them into one file, in fact is not the most
efficent way to handle them. Put them all in a directory and run tile4ms
utility on them to create a tileindex and then make a layer that uses
the tileindex. If the shapefiles have a lot of data in them, you might
also want to generate a spatial index for each shape file using the
shptree utility.
Hope this helps,
-Steve W.
teb wrote:
> ------------- Begin Forwarded Message -------------
> From: CoadyT at DFO-MPO.GC.CA
> To: mapserver-info at lists.gis.umn.edu
> Subject: Joining ShapeFiles
> Date: Mon, 11 Feb 2002 12:44:49 -0500
> MIME-Version: 1.0
> I am working with more than one area in my map file. I need to place all the
> land in one layer. I have 8 different shape files for different areas of the
> map. Is it possible to join them in one layer. If so can you give me some
> example code to combine them. I am trying to make my map open faster. Will
> this help or hurt? I just found out by reading off of your homepage that
> joins are only availabe in Queries. So is it possible to join these files
> using my .map file in a layer?
> Tony Coady
> Programmer Analyst
> Coroporate Services
> Information Management & Technology Services Branch
> St John's NF
> White Hills Building
> A1C 5X1
> (709)772-6272
> ------------- End Forwarded Message -------------
