[mapserver-users] New to Mapserver
Sathiskumar Govindasamy
gsathis at yahoo.com
Mon Feb 11 14:11:01 EST 2002
Steve,
Is there a way to look at the contents of shapefile or its realted file
to know what is in it ?
Sathis
Stephen Woodbridge wrote:
>Sathis,
>The EXTENT in the map file is wrong. The census data is in Decimal
>Degrees so it should look like
>EXTENT -180.0 -90.0 180.0 90.0
>which will cover the whole globe, you can set these numbers smaller
>based on the real extents of you shapefile.
>-Steve W.
