[mapserver-users] New to Mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 11 14:17:45 EST 2002
Yes, there are two utility programs the come with shapelib (dbfdump and
shpdump) that are comand line utilities (on Windows you have to run them
from a DOS window) dbfdump prints all the attributes from the .dbf file
and shpdump prints the shapefile extents and then all the coordinate
info for every shape in the shape file.
-Steve W.
Sathiskumar Govindasamy wrote:
> Steve,
> Is there a way to look at the contents of shapefile or its realted file
> to know what is in it ?
> Sathis
> Stephen Woodbridge wrote:
> >Sathis,
> >The EXTENT in the map file is wrong. The census data is in Decimal
> >Degrees so it should look like
> >EXTENT -180.0 -90.0 180.0 90.0
> >which will cover the whole globe, you can set these numbers smaller
> >based on the real extents of you shapefile.
> >-Steve W.
