[mapserver-users] New to Mapserver
Sathiskumar Govindasamy
gsathis at yahoo.com
Mon Feb 11 18:27:42 EST 2002
Thanks guys it works great. Thanks for your help. Yet another question.
I downloaded shapefiles from nationalatlas.gov. In the state boundaries
map, it has all the states in one shapefile. Is there a way to ignore
Alaska, U.S. Virgin Islands, Puerto Rico, etc keeping just the mainland
US ?
-Sathis
Stephen Woodbridge wrote:
>Yes, there are two utility programs the come with shapelib (dbfdump and
>shpdump) that are comand line utilities (on Windows you have to run them
>from a DOS window) dbfdump prints all the attributes from the .dbf file
>and shpdump prints the shapefile extents and then all the coordinate
>info for every shape in the shape file.
>-Steve W.
>Sathiskumar Govindasamy wrote:
>>Steve,
>>Is there a way to look at the contents of shapefile or its realted file
>>to know what is in it ?
>>Sathis
>>>Sathis,
>>>The EXTENT in the map file is wrong. The census data is in Decimal
>>>Degrees so it should look like
>>>EXTENT -180.0 -90.0 180.0 90.0
>>>which will cover the whole globe, you can set these numbers smaller
>>>based on the real extents of you shapefile.
>>>-Steve W.
