[mapserver-users] New to Mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 11 18:47:48 EST 2002
Yes, you can set you EXTENTS in the mapfile to just cover the mainland.
-Steve
Sathiskumar Govindasamy wrote:
> Thanks guys it works great. Thanks for your help. Yet another question.
> I downloaded shapefiles from nationalatlas.gov. In the state boundaries
> map, it has all the states in one shapefile. Is there a way to ignore
> Alaska, U.S. Virgin Islands, Puerto Rico, etc keeping just the mainland
> US ?
> -Sathis
> Stephen Woodbridge wrote:
> >Yes, there are two utility programs the come with shapelib (dbfdump and
> >shpdump) that are comand line utilities (on Windows you have to run them
> >from a DOS window) dbfdump prints all the attributes from the .dbf file
> >and shpdump prints the shapefile extents and then all the coordinate
> >info for every shape in the shape file.
> >-Steve W.
> >>Steve,
> >>Is there a way to look at the contents of shapefile or its realted file
> >>to know what is in it ?
> >>Sathis
> >>>Sathis,
> >>>The EXTENT in the map file is wrong. The census data is in Decimal
> >>>Degrees so it should look like
> >>>EXTENT -180.0 -90.0 180.0 90.0
> >>>which will cover the whole globe, you can set these numbers smaller
> >>>based on the real extents of you shapefile.
> >>>-Steve W.
