[mapserver-users] problem with oracle spatial layer not showing up
Bart van den Eijnden
bart at geodan.nl
Tue Feb 12 12:50:08 EST 2002
I have a problem with an Oracle Spatial layer not showing up. Can anybody please help? Thanks in advance!
EPSG:29112 is the Dutch system (Rijksdriehoek a.k.a RD)
In the logfile I get this:
Tue Feb 12 18:22:12 2002,2200,192.168.3.141,DEMO,0,18458.421916 323458.421916 346541.578084 651541.578084,182500.000000
487500.000000,oracle_test ,normal execution
The mapfile looks like this
# Start of map file
NAME BART
STATUS ON
SIZE 600 600
EXTENT 0 275000 365000 700000
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
LOG "demo.log"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://bartsdt/mapserver_demos/itasca/demo_init.html"
WMS_SRS "EPSG:29112"
END
END
# Start of layer definitions
LAYER
NAME oracle_test
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "robert/robert at des"
DATA "POLYGOON FROM (SELECT POLYGOON FROM GGA_GEMEENTE_EFEMERIDEN)"
STATUS ON
#LABELITEM "PVE_CODE"
#CLASSITEM "PVE_CODE"
#LABELMAXSCALE 500000
#CLASS
# EXPRESSION /./
# COLOR -1 -1 -1
# LABEL
# COLOR 0 0 0
# SHADOWCOLOR 218 218 218
# SHADOWSIZE 2 2
# TYPE BITMAP
# SIZE MEDIUM
# POSITION CC
# PARTIALS FALSE
# BUFFER 2
END
END
METADATA
WMS_TITLE "Minor Civil Divisions"
WMS_ABSTRACT "Minor civil divisions for Itasca County. (annotation only)"
END
END
Bart van den Eijnden Geodan IT BV
Email: bart at geodan.nl Buitenhaven 27-A
Telefoon: 073-6925151 5211 TP 's-Hertogenbosch
