[mapserver-users] Length of a line calculation?
Vinko Vrsalovic
v at w.cl
Mon Feb 18 12:47:55 EST 2002
Hello,
I'm wanting to do the following in MapScript, but don't know
if it's possible.
Suppose i have a LINE layer from a shapefile that only has one
attribute in its DBF file. Then I select all the shapes from the
shapefile that match a certain criteria in the attribute, now i
want to know, for instance, how long are all the shapes i
selected.
Can I do that? (Obtain the length in ground units of a selected
shape). How, if possible, can that be done? And last, but not
least, is the procedure generalizable to polygons to obtain its
area or perimeter?
Thank you,
V. <v at w.cl>
