[mapserver-users] permissions for MS IIS on windows 2000
Obe, Regina DND\MIS
Regina.Obe.PFD at ci.boston.ma.us
Tue Feb 19 09:52:44 EST 2002
The folder that contains mapserv.exe - the IUSR account has to have execute
rights
For the folder where the temp images will be installed, IUSR has to have
write rights to that folder and the temp folder must also be accessible as a
web URL.
i.e. if you use c:/inetpub/wwwroot/tmp for example - that is usually
already accessible as a web url of the form
http://localhost/tmp
But if you put the temp folder anywhere outside your web root path, you'll
need to make it a virtual directory via IIS Manager.
-----Original Message-----
From: Jessica Anderson [mailto:janderson at PacificDataServices.com]
Sent: Monday, February 18, 2002 12:46 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] permissions for MS IIS on windows 2000
Are there certain permissions I need to set in IIS for it to run mapserver?
Jessica Anderson
Pacific Data Services
PH. (209) 524-2479
FAX. (209) 524-0282
