[mapserver-users] Query and template files
Azimuth, Erwin Perik
perik at azimuth.nl
Wed Feb 20 03:18:59 EST 2002
Hi Michel,
In the GMAP version the query (by button) is retreiving information
according to METADATA set in your layers.
Basicly it goes like this:
1) GMap75CheckClick() --> checks user input on the rosa-map, eg zoom-in
zoom-out, pan, query.
2) When query button is used and then user clicks on map it uses following:
else if ($HTTP_FORM_VARS["CMD"] == "QUERY_POINT")
a) here it checks if point or rectangle is used
b) pixel-coords are then translated to geo-coords
c) query:
* @$gpoMap->queryByPoint($oClickGeo, MS_SINGLE, -1); <--
queries the map (single point)
* @$gpoMap->queryByRect($oGeorefRect); <-- queries the map
(rectangle)
d) $gbShowQueryResults = TRUE; <-- query is used
e) it now reloads gmap.php
f) in gmap.php you see: <?php GMapDumpQueryResults(); ?>
g) this uses the function GMapDumpQueryResults()
h) In your map-file, it checks for the following in every layer:
METADATA
"DESCRIPTION" "PrintedDescription"
"RESULT_FIELDS" "FIELD ANOTHER_FILED" # Field names of you
.dbf-file
END
i) if it finds metadata it passes it to the main file (gmap.php)
j) also any found objects are now highlighted in the main map
* Every time gmap.php is loaded it uses the function GMapDrawMap() :
if ($gbShowQueryResults) // <-- found objects, so drawQuery,
highlights the objects
$img = $gpoMap->drawQuery();
else // <-- nothing found, draw normal map
(nothing changes)
$img = $gpoMap->draw();
k) General info: certain Variables (like $gpoMap) are set to global to use
for other functions
You now can add features like:
NewExtent --> map zooms in to the rectangle you used for query based on the
geo-coords of the rectangle
I never got into the CGI stuff cause i loced the combination of Mapscript
and Rosa, so sticking with that.
Good luck,
Erwin
At 15:08 19-2-02 -0300, Michel M. dos Santos wrote:
> Hello ,
> In the example of Itasca , with cgi mode the queries are done by
> templates
>files. With the example of gmap , with mapscript/php are done other way. I'm
>confused with this.
> Somebody can help me ?
>[]'s
Azimuth Geodetic
Koldingweg 8
9723 HK Groningen
tel. 050-5493454
fax. 050-5497217
www.azimuth.nl
perik at azimuth.nl
