[mapserver-users] Query and template files
Michel M. dos Santos
michel at omnisystem.com.br
Thu Feb 21 15:14:01 EST 2002
Thanks Erwin,
I have another question:
I want to do a search, for example, by name of the streets. In my html page
I put a form for the user write the street he wants to search. The street is
localized and displayed in the map. I need to search the record in dbf file
and after in shape file ? I now the relation between dbf file and shape file
are done by record number, correct ?
[]'s
Em Qua 20 Fev 2002 05:18, Azimuth, Erwin Perik escreveu:
> Hi Michel,
> In the GMAP version the query (by button) is retreiving information
> according to METADATA set in your layers.
> Basicly it goes like this:
> 1) GMap75CheckClick() --> checks user input on the rosa-map, eg zoom-in
> zoom-out, pan, query.
> 2) When query button is used and then user clicks on map it uses following:
> else if ($HTTP_FORM_VARS["CMD"] == "QUERY_POINT")
> a) here it checks if point or rectangle is used
> b) pixel-coords are then translated to geo-coords
> c) query:
> * @$gpoMap->queryByPoint($oClickGeo, MS_SINGLE, -1); <--
> queries the map (single point)
> * @$gpoMap->queryByRect($oGeorefRect); <-- queries the map
> (rectangle)
> d) $gbShowQueryResults = TRUE; <-- query is used
> e) it now reloads gmap.php
> f) in gmap.php you see: <?php GMapDumpQueryResults(); ?>
> g) this uses the function GMapDumpQueryResults()
> h) In your map-file, it checks for the following in every layer:
> METADATA
> "DESCRIPTION" "PrintedDescription"
> "RESULT_FIELDS" "FIELD ANOTHER_FILED" # Field names of you
> .dbf-file
> END
> i) if it finds metadata it passes it to the main file (gmap.php)
> j) also any found objects are now highlighted in the main map
> * Every time gmap.php is loaded it uses the function GMapDrawMap() :
> if ($gbShowQueryResults) // <-- found objects, so drawQuery,
> highlights the objects
> $img = $gpoMap->drawQuery();
> else // <-- nothing found, draw normal map
> (nothing changes)
> $img = $gpoMap->draw();
> k) General info: certain Variables (like $gpoMap) are set to global to use
> for other functions
> You now can add features like:
> NewExtent --> map zooms in to the rectangle you used for query based on the
> geo-coords of the rectangle
> I never got into the CGI stuff cause i loced the combination of Mapscript
> and Rosa, so sticking with that.
> Good luck,
> Erwin
> At 15:08 19-2-02 -0300, Michel M. dos Santos wrote:
> > Hello ,
> > In the example of Itasca , with cgi mode the queries are done by
> > templates
> >files. With the example of gmap , with mapscript/php are done other way.
> > I'm confused with this.
> > Somebody can help me ?
> >[]'s
> Azimuth Geodetic
> Koldingweg 8
> 9723 HK Groningen
> tel. 050-5493454
> fax. 050-5497217
> www.azimuth.nl
> perik at azimuth.nl
