[mapserver-users] Query and template files
Azimuth, Erwin Perik
perik at azimuth.nl
Fri Feb 22 08:06:59 EST 2002
Hi Michel,
Mmm,... coinsidence,.... working on about the same idea as you described ;-)
Relationship is ok. Once you have the correct row you can then use that one
to search for the shape.
Myself i use PHP mapscript,... where i do it like this:
Search-Field ---> calls a javascript --> pass variables (like the
search-field) to a popup window.
This popup is a php file which uses the variables bassed by the javascript.
In that popup-php it searches the dbf using standard PHP functions. It then
returns both fields and values of the found row(s).
These fields are then passed to the popup-page.
It then is possible (you have it's index) to get the shape, create new
extents, create the image and show it.
Highlighting is still my problem,.... i can only get the complete layer to
highlight, but as it's zoomed in (shape-extents) it is no real bother.
I do however want to show only the found shape in an overview-map, but not
found out how yet. Tried numerous, but all failed.
Any help regarding this would be great ;-)
Erwin
At 17:14 21-2-02 -0300, Michel M. dos Santos wrote:
> Thanks Erwin,
> I have another question:
> I want to do a search, for example, by name of the streets. In my
> html page
>I put a form for the user write the street he wants to search. The street is
>localized and displayed in the map. I need to search the record in dbf file
>and after in shape file ? I now the relation between dbf file and shape file
>are done by record number, correct ?
>[]'s
>Em Qua 20 Fev 2002 05:18, Azimuth, Erwin Perik escreveu:
> > Hi Michel,
> > In the GMAP version the query (by button) is retreiving information
> > according to METADATA set in your layers.
> > Basicly it goes like this:
> > 1) GMap75CheckClick() --> checks user input on the rosa-map, eg zoom-in
> > zoom-out, pan, query.
> > 2) When query button is used and then user clicks on map it uses following:
> > else if ($HTTP_FORM_VARS["CMD"] == "QUERY_POINT")
> > a) here it checks if point or rectangle is used
> > b) pixel-coords are then translated to geo-coords
> > c) query:
> > * @$gpoMap->queryByPoint($oClickGeo, MS_SINGLE, -1); <--
> > queries the map (single point)
> > * @$gpoMap->queryByRect($oGeorefRect); <-- queries the map
> > (rectangle)
> > d) $gbShowQueryResults = TRUE; <-- query is used
> > e) it now reloads gmap.php
> > f) in gmap.php you see: <?php GMapDumpQueryResults(); ?>
> > g) this uses the function GMapDumpQueryResults()
> > h) In your map-file, it checks for the following in every layer:
> > METADATA
> > "DESCRIPTION" "PrintedDescription"
> > "RESULT_FIELDS" "FIELD ANOTHER_FILED" # Field names of you
> > .dbf-file
> > END
> > i) if it finds metadata it passes it to the main file (gmap.php)
> > j) also any found objects are now highlighted in the main map
> > * Every time gmap.php is loaded it uses the function GMapDrawMap() :
> > if ($gbShowQueryResults) // <-- found objects, so drawQuery,
> > highlights the objects
> > $img = $gpoMap->drawQuery();
> > else // <-- nothing found, draw normal map
> > (nothing changes)
> > $img = $gpoMap->draw();
> > k) General info: certain Variables (like $gpoMap) are set to global to use
> > for other functions
> > You now can add features like:
> > NewExtent --> map zooms in to the rectangle you used for query based on the
> > geo-coords of the rectangle
> > I never got into the CGI stuff cause i loced the combination of Mapscript
> > and Rosa, so sticking with that.
> > Good luck,
> > Erwin
> > At 15:08 19-2-02 -0300, Michel M. dos Santos wrote:
> > > Hello ,
> > > In the example of Itasca , with cgi mode the queries are done by
> > > templates
> > >files. With the example of gmap , with mapscript/php are done other way.
> > > I'm confused with this.
> > > Somebody can help me ?
> > >[]'s
> > Azimuth Geodetic
> > Koldingweg 8
> > 9723 HK Groningen
> > tel. 050-5493454
> > fax. 050-5497217
> > www.azimuth.nl
> > perik at azimuth.nl
Azimuth Geodetic
Koldingweg 8
9723 HK Groningen
tel. 050-5493454
fax. 050-5497217
www.azimuth.nl
perik at azimuth.nl
