[mapserver-users] Date: Tue, 19 Feb 2002 15:44:41 -0500
Steve Lime
steve.lime at dnr.state.mn.us
Wed Feb 20 10:46:46 EST 2002
At the moment you can't do an itemquery on more than one layer at a
time. There is
no workaround for this at the moment (other than using mapscript-
sorry. It's not a
limitation in the query code per se but rather a limitation in how the
CGI program
considers the qlayer parameter. There is already a feature request that
has been filed
in bugzilla requesting the ability to set multiple query layers and I
hope to address
this soon.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Shaik Anwar Hussain <shussain at atsincorp.com> 02/19/02 02:48PM >>>
Hi Friends,
Thanks for your help, its working fine for filtering one layer.
I changed my query like following and it working fine.
http://208.163.164.119:6500/cgi-bin/mapserv?map=../htdocs/pams1/pams.map&lay
ers=flightline&mode=itemnquery&zoomdir=0&imgxy=585 295&imgext=300434
-148033
322234 1655445&zoomsize=2&mapext=-252600 -148033 274400 165545
&qlayer=flightline&map_flightline_header=mapdisplay.html&map_flightline_temp
late=zoomto.html&map_flightline_filter=%22204A%22%22218A%22
I want to do filtering multiple layers, i passed the url like
-148033
&qlayer=flightline photo
&map_flightline_header=mapdisplay.html&map_flightline_template=zoomto.html&m
&map_photo_header=mapdisplay.html&map_photo_template=zoomto.html&map_photo_f
where flightline and photo are two layers.
Do you think what i am passing the url is correct to do multiple
filters.
i am getting the error like
msQueryByAttributes(): General error message. No query layer defined.
i defined the filter item in my map file for the two layers.
Can any one help me whats wrong in that url.
Thanks,
Anwar
