[mapserver-users] Compilation problem
Vladimir Guzmán
vguzman at bigfoot.com
Fri Feb 22 15:12:19 EST 2002
I'm sorry about that.
I was missing the complete path in --with-apxs
Now it works fine. Thank you.
Vladimir Guzmán wrote:
> Hello list.
> Please, I have installed apache with this configure:
> ./configure --enable-module=so
> php 4.06 with:
> ./configure --with-dbase=yes
> --with-system-regex
> --with-png=yes
> --without-ttf
> --with-apxs=/usr/local/apache/bin/apxs
> --with-mysql
> --with-pgsql
> --with-config-file-path=/etc
> Mapserver 4.05 with:
> ./configure --with-gd --with-php=/programas/php-4.0.6 --with-apxs
> --with-sde --with-ttf
=/usr/local/apache/bin/apxs --with-sde --with-ttf
> Everything works fine, the configure and the make, but when I try to
> load the module, the page in the browser says:
> Warning*: Unable to load dynamic library
> '/usr/local/lib/php/extensions/php_mapscript.so' -
> php_mapscript_util.o: cannot open shared object file: No such file or
> directory in */usr/local/apache/htdocs/prueba.php* on line *2*
> Am I missing something?
> I've searched on the list, but it points to re-compile apache.
> I'm using Suse 7.3
> Thanks a lot,
Vladimir Guzmán R.
www.main-task.com
