[mapserver-users] oraclespatial connect error
PARVILLERS
hugues at parvillers.com
Sat Feb 23 02:40:16 EST 2002
Hello,
don't you have more than one Oracle install on your local server ? May be the
Oci don't look in the right tnsnames.ora file ?
Yu-Hsin Chen a écrit :
> Well, my problem is that the database is not on the local machine. I
> guess I could create the local database and test it out. If that is
> successful I can always create database link in Oracle to access the
> real data.
> Thanks for the tip on DATA. I will have more questions back on this
> item.
> Yu-Hsin
> -----Original Message-----
> From: Rodrigo Cabral
> Sent: Fri 2/22/2002 7:32 PM
> To: Yu-Hsin Chen; mapserver-users at lists.gis.umn.edu
> Cc:
> Subject: Re: [mapserver-users] oraclespatial connect error
> Your error means that the Oracle client cannot find the database
> (service)
> to connect. Try using simply 'username/password' for CONNECTION to see
> if
> the default service works.
> Also, your DATA statement is not going to work. 'circle' must be in the
> select list. Like "circle from (select circle...)". BUT, why are you
> doing
> that? Try this:
> DATA "circle FROM room_geoloc"
> or
> DATA "circle FROM room_geoloc USING SRID <srid#>" if you have an srid
> number
> defined.
> Rod.
> ----- Original Message -----
> From: "Yu-Hsin Chen" <ychen at yorktel.com>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, February 22, 2002 4:04 PM
> Subject: [mapserver-users] oraclespatial connect error
> I've compiled mapserver 3.5 with oraclespatial option on my Mandrake
> Linux 8.0 with Oracle 8.1.7i. When I run sqlplus at Linux prompt I can
> get to the database with un/pw at bis login. However, when I tried it from
> a map file I get "msOCIConnect() in msOracleSpatialLayerOpen():
> OracleSpatial error. Error while trying to retrieve text for error
> ORA-12541" in my browser. ORA-12541 is "TNS:could not resolve service
> name".
> My map file looks like this:
> LAYER
> NAME "oracle"
> CONNECTIONTYPE oraclespatial
> CONNECTION 'un/pw at bis'
> DATA "circle from (select room_id, longitude, latitude from
> room_geoloc)"
> TYPE POINT
> STATUS ON
> END
> Thanks in advance to whoever can help me.
> Yu-Hsin Chen
> winmail.dat Type: application/ms-tnef
> Encoding: base64
