[mapserver-users] oraclespatial connect error
Rodrigo Cabral
cabral at yadata.net
Sat Feb 23 08:20:12 EST 2002
Which binary of mapserver are you using? Windows or Unix? -- just for
curiosity
Also, you could try to track the error by running sqlplus and trying to
connect to the database. You should get the same TNS error when you try to
connect.
Rod.
----- Original Message -----
Sent: Saturday, February 23, 2002 4:40 AM
Subject: Re: [mapserver-users] oraclespatial connect error
Hello,
don't you have more than one Oracle install on your local server ? May be
the
Oci don't look in the right tnsnames.ora file ?
Yu-Hsin Chen a écrit :
> Well, my problem is that the database is not on the local machine. I
> guess I could create the local database and test it out. If that is
> successful I can always create database link in Oracle to access the
> real data.
> Thanks for the tip on DATA. I will have more questions back on this
> item.
> Yu-Hsin
> -----Original Message-----
> From: Rodrigo Cabral
> Sent: Fri 2/22/2002 7:32 PM
> To: Yu-Hsin Chen; mapserver-users at lists.gis.umn.edu
> Cc:
> Your error means that the Oracle client cannot find the database
> (service)
> to connect. Try using simply 'username/password' for CONNECTION to see
> if
> the default service works.
> Also, your DATA statement is not going to work. 'circle' must be in the
> select list. Like "circle from (select circle...)". BUT, why are you
> doing
> that? Try this:
> DATA "circle FROM room_geoloc"
> or
> DATA "circle FROM room_geoloc USING SRID <srid#>" if you have an srid
> number
> defined.
> Rod.
> From: "Yu-Hsin Chen" <ychen at yorktel.com>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, February 22, 2002 4:04 PM
> Subject: [mapserver-users] oraclespatial connect error
> I've compiled mapserver 3.5 with oraclespatial option on my Mandrake
> Linux 8.0 with Oracle 8.1.7i. When I run sqlplus at Linux prompt I can
> get to the database with un/pw at bis login. However, when I tried it from
> a map file I get "msOCIConnect() in msOracleSpatialLayerOpen():
> OracleSpatial error. Error while trying to retrieve text for error
> ORA-12541" in my browser. ORA-12541 is "TNS:could not resolve service
> name".
> My map file looks like this:
> LAYER
> NAME "oracle"
> CONNECTIONTYPE oraclespatial
> CONNECTION 'un/pw at bis'
> DATA "circle from (select room_id, longitude, latitude from
> room_geoloc)"
> TYPE POINT
> STATUS ON
> END
> Thanks in advance to whoever can help me.
> Yu-Hsin Chen
> winmail.dat Type: application/ms-tnef
> Encoding: base64
