[mapserver-users] help with raster
Francois Michel Le Tourneau
letourne at mercator.ens.fr
Sat Feb 23 07:56:07 EST 2002
Hello !
I am trying to use raster data within mapserver, which does not work.
I have atempted to use various version of mapserver, compiled
with or without gdal support. My data is geotiff, with the following
indications extracted by gdalinfo :
Driver: GTiff/GeoTIFF
Size is 5441, 4851
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223562997]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Origin = (-65.030748,3.840657)
Pixel Size = (0.000400,-0.000400)
Corner Coordinates:
Upper Left ( -65.0307480, 3.8406570) ( 65d 1'50.69"W, 3d50'26.37"N)
Lower Left ( -65.0307480, 1.9002570) ( 65d 1'50.69"W, 1d54'0.93"N)
Upper Right ( -62.8543481, 3.8406570) ( 62d51'15.65"W, 3d50'26.37"N)
Lower Right ( -62.8543481, 1.9002570) ( 62d51'15.65"W, 1d54'0.93"N)
Center ( -63.9425480, 2.8704570) ( 63d56'33.17"W, 2d52'13.65"N)
My mapfile is the simplest ever :
NAME mymap
SIZE 500 500
EXTENT -65 2 -63 4
SHAPEPATH "data1"
SYMBOLSET marker.sym
WEB
TEMPLATE dessine_carte.html
EMPTY /cartes/empty.html
IMAGEPATH "/usr/local/httpd/htdocs/tmp/"
IMAGEURL "/tmp/"
LOG "/tmp/log.log"
END
LAYER
NAME "Im"
DATA "Landsat2.tif"
TYPE RASTER
STATUS ON
END
END # end of map file
In the log file, I can see :
Sat Feb 23 12:41:32 2002,22416,195.132.244.162,mymap,0,-65.498000 2.000000
-63 4.000000,-1.000000 -1.000000,,normal execution
The result is a blank image of 500x500 pixels.
I would like to know :
1. how to understand every statement of the log file
2. how to test simply the raster capability of my mapserver
3. how i can understand what is going on with the raster
data for it not being displayed
Thanks in advance for any answer
François-Michel Le Tourneau
Francois-Michel Le Tourneau
Chargé de Recherches au CNRS
Centre de Recherche et de Documentation sur l'Amérique Latine (UMR 7530)
Tel. 01 44 39 86 85 Fax. 01 45 48 79 58
E-mail : Francois.Michel.Le.Tourneau at ens.fr
