[mapserver-users] Example of Cold Fusion....
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Feb 26 15:20:45 EST 2002
> I am new to using mapserver; however, experienced in cold
> fusion and was
> wondering if anyone could send me an example exactly how you
> can integrate
> this tool with cold fusion?
can't really, in the mapscript kind-of way, at least not yet. However, you
can do something like this... works quite well.
<cfset map="c:/path/to/your/mapfile.map">
<cfparam name="layer" default="counties">
<cfparam name="mode" default="browse">
<cfparam name="zoomsize" default="2">
<cfparam name="zoomdir" default="1">
<cfparam name="imgxy" default="329 249">
<cfparam name="imgbox" default="-1 -1 -1 -1">
<cfhttp
url="http://server/cgi-bin/mapserv.exe?map=#map#&layer=#layer#&zoomsize=#zoo
msize#&mode=#mode#&zoomdir=#zoomdir#&mapext=shapes"
method="get"
resolveurl="true">
</cfhttp>
<cfform name="mapserv" method="post" action="thisfile.cfm">
<cfoutput>#cfhttp.FileContent#</cfoutput>
<input type="hidden" name="savequery" value="true">
</cfform>
hth.
pk/
