[mapserver-users] Help: MS 3.5 PHP3 MapScript Install
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 4 10:25:08 EST 2002
Hi all,
I can't get PHP3 Mapscript to run on my RH 6.2 Linux with Apache.
It seems to have built OK and I moved the php_mapscript.so to the
/usr/lib/apache directory and tried to run the phpinfo_mapscript.phtml
script via the server but all I get is the "Document Contained No Data"
dialog box which usually indicates the process crashed.
Here is how I configured it:
./configure --enable-shared --enable-modules --enable-lzw
--without-magick-plus-plus --with-perl-options=PREFIX=/usr --with-ogr
--with-gdal --with-wmsclient --with-proj
--with-php=../../linux/php-3.0.16 --with-apxs=/usr/sbin/apxs
Any ideas on what to check or how to debug this?
-Steve
