[mapserver-users] Which Java JDK?
Grant Marblestone
GrantM at ATSER.com
Wed Jan 23 11:51:24 EST 2002
This is a semi-educated guess as i mostly work with jsp's and swing and not
applets. HOwever i believe
you should not have to worry about java as far as applets go. The applet
class has changed little. The latest stable release will work on all java
browsers.
Download here
http://java.sun.com/j2se/1.3/download-linux.html
More info here
http://java.sun.com/j2se/1.3/docs/relnotes/features.html#applet
Go here to read about it.
Grant
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
Sent: Wednesday, January 23, 2002 8:47 AM
I want to get a Java JDK for my RedHat 6.2 Linux box so I can try and make
some changes to the Rosa applet. I want the applet to run in the existing
browsers.
Which Java JDK should I get?
Do I need to worry about Java 1 vs Java 2?
Where should I get it from?
Thanks for any help you can offer,
-Steve
