[mapserver-users] Which Java JDK?
Paul Ramsey
pramsey at refractions.net
Wed Jan 23 12:37:22 EST 2002
Java 1.1 only. For whatever sad reason (*cough* MicroSoft *cough*) Java
in browsers never advanced past Java 1.1. Which in some ways is nice,
because there is not a huge mixed set of Java versions out there to
worry about (*cough* ignoring VM implementation issues *cough*).
Grant Marblestone wrote:
> This is a semi-educated guess as i mostly work with jsp's and swing and not
> applets. HOwever i believe
> you should not have to worry about java as far as applets go. The applet
> class has changed little. The latest stable release will work on all java
> browsers.
> Download here
> http://java.sun.com/j2se/1.3/download-linux.html
> More info here
> http://java.sun.com/j2se/1.3/docs/relnotes/features.html#applet
> Go here to read about it.
> Grant
> ----- Original Message -----
> From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
> Sent: Wednesday, January 23, 2002 8:47 AM
> I want to get a Java JDK for my RedHat 6.2 Linux box so I can try and make
> some changes to the Rosa applet. I want the applet to run in the existing
> browsers.
> Which Java JDK should I get?
> Do I need to worry about Java 1 vs Java 2?
> Where should I get it from?
> Thanks for any help you can offer,
> -Steve
