[mapserver-users] Which Java JDK?
Francisco
fgclaram at alu-ab.uclm.es
Wed Jan 23 12:52:42 EST 2002
Hi again.
I used it for applets, and I did't have problems.
if you don't use swing class you will not need plugin.
Or, if you prefer download JDK 1.2 (beware with swing).
Ok, if you put a Java applet into a Web page, the browser client always
need a plugin.
But this plugin is included in most of browsers.
If you use swing class you will need Java2 plugin, this one I think is not
included in all browsers (I'm not sure).
Fran.
At 11.11 23/1/02 -0600, Steve Lime wrote:
>With 1.3 won't you need a plugin to run the applet though?
>Stephen Lime
>Data & Applications Manager
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
> >>> Francisco <fgclaram at alu-ab.uclm.es> 01/23/02 11:00AM >>>
>Hello.
>You can get JDK 1.3.x and you will not have problems (I suppose).
>You can download from http://java.sun.com/j2se/1.3/download-linux.html
>Regards,
>Fran.
>At 09.47 23/1/02 -0500, Stephen Woodbridge wrote:
> >Sorry, if this is a little off topic.
> >I want to get a Java JDK for my RedHat 6.2 Linux box so I can try and
> >make some changes to the Rosa applet. I want the applet to run in the
> >existing browsers.
> >Which Java JDK should I get?
> >Do I need to worry about Java 1 vs Java 2?
> >Where should I get it from?
> >Thanks for any help you can offer,
> > -Steve
