[mapserver-users] Which Java JDK?
Andrew
ahaigh at ic24.net
Wed Jan 23 13:58:34 EST 2002
You only need the JDK 1.3 plugin if you use any features associated with JDK
1.3 or JDK 1.2. For standard applet stuff you should fine using JDK 1.3 for
development.
The docs for JDK 1.1 are still on the sun site if you want them for
reference.
Andrew
----- Original Message -----
To: "Steve Lime" <steve.lime at dnr.state.mn.us>;
<mapserver-users at lists.gis.umn.edu>; <woodbri at swoodbridge.com>
Sent: Wednesday, January 23, 2002 5:21 PM
Subject: Re: [mapserver-users] Which Java JDK?
> Hi,
> I used it for applets, and I did't have problems.
> if you don't use swing class you will not need plugin.
> Or, if you prefer download JDK 1.2 (beware with swing).
> Fran.
> At 11.11 23/1/02 -0600, Steve Lime wrote:
> >With 1.3 won't you need a plugin to run the applet though?
> >Stephen Lime
> >Data & Applications Manager
> >Minnesota DNR
> >500 Lafayette Road
> >St. Paul, MN 55155
> >651-297-2937
> > >>> Francisco <fgclaram at alu-ab.uclm.es> 01/23/02 11:00AM >>>
> >Hello.
> >You can get JDK 1.3.x and you will not have problems (I suppose).
> >You can download from http://java.sun.com/j2se/1.3/download-linux.html
> >Regards,
> >Fran.
> >At 09.47 23/1/02 -0500, Stephen Woodbridge wrote:
> > >Sorry, if this is a little off topic.
> > >I want to get a Java JDK for my RedHat 6.2 Linux box so I can try and
> > >make some changes to the Rosa applet. I want the applet to run in the
> > >existing browsers.
> > >Which Java JDK should I get?
> > >Do I need to worry about Java 1 vs Java 2?
> > >Where should I get it from?
> > >Thanks for any help you can offer,
> > > -Steve
