[mapserver-users] missing __init__ in python mapscript (fwd)
Norman Vine
nhv at cape.com
Sun Jan 27 06:45:02 EST 2002
Tom Russell writes:
>Norman,
>It appears that the problem is indeed related to the Setup
>file, as I was
>able to reproduce the 'missing __init__" error on a sample project by
>leaving out a middle term, which is the original c source file(s).
>Apparently, it should be something like the following:
>*shared*
>mapscriptc layer.c label.c mapfile.c ... mapscript_wrap.c
>It doesn't seem correct that every Mapserver source file
>should have to be listed, though.
Apologies
you also need to add all of the libraries that are needed by mapserver
and necessary include paths ie the same as you would pass to
a cli invocation of gcc to link a module against libmap.a
see your python_source / Modules / setup file for examples of
how this is done for other modules
HOWEVER this is a deprecated way of building extension modules
unfortunately because mapserver can be configured in a multitude
of different configurations it is difficult to come up with a generic
python distutils script which would make this trivial.
I have put a python script at
http://www.vso.cape.com/~nhv/files/python/mapscript/setup.py
That I use to build a fairly 'stock' python mapscript module
on Cygwin that might just work for you and can at least be used as a
'template' for building a python mapscript on other systems
YMMV
Cheers
Norman
