[mapserver-users] tiff problem,
Ed McNierney
ed at topozone.com
Thu Jan 31 11:33:01 EST 2002
Pushkar -
You should be able to run GeoTIFFs just fine with MapServer w/o GDAL
support if it was built with TIFF support. Run "mapserv -v" and check
to see that "INPUT=TIFF" is listed. However, it looked like (from your
previous email) that you are using a 24-bit RGB TIFF image. That is NOT
supported w/o GDAL - using GDAL in MapServer 3.5 will give you 24-bit
TIFF support. However, you might want to really consider pre-processing
your images down to 8 bits BEFORE they're used by MapServer.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Thursday, January 31, 2002 11:07 AM
To: Pushkar Pradhan
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] tiff problem,
Pushkar Pradhan wrote:
>I've tried giving absolute paths in the DATA field but it gives me
Internal
>Server Error.
>The TIFs are GEOTIFFS,
>Do I need to have projection support enabled to display GEOTIFFs, sorry
I
>am not experienced in GIS field. Thanks,
Good Question. I am not sure. Here we compiled it to run with the GDAL
library (www.remotesensing.org) and have been using that to read both
GEOTIFF and regular TIFF's with ESRI world files. I have not tried to
use it with the straight tifflib.
My guess is that you do not have geotiff capablility. I am not sure how
Mapserver without GDAL deals with this. It might require an ESRI world
file. See if you can find a tool that will export the geotiff tags to
an ESRI world file with the same name and a .tfw extension. Then place
the world file in the same directory as the Tiff imagery. Or ask
someone more knowlegable than me.
Any help out there?
Dave Graham
