[mapserver-users] Compiling PHP-Mapscript FreeBSD 4.5
Bob Carr
racarr at ameritech.net
Sat Jun 15 07:16:40 PDT 2002
Steve,
I find libz.a in /usr/lib/libz.a. In the MS_LIBS variable in
mapscript/php3/Makefile, I have -L/usr/lib -lz. In the ./configure
input string I have --with-php=/usr/home/racarr/downloads/php-4.1.1
Here's a link to a test.php file on my server. Is there anything there
that appears out-of-line?
www.geologic.dyndns.org/test.php
Thanks.
In a previous message Stephen Woodbridge wrote:
> Bob,
> This is only a guess, but the zend_* functions are in libz.a which
> should be referenced via -lz option which may not be being found. check
> where it is located (like: /usr/local/lib/libz.a) with "whereis libz"
> and make sure you have a -L/usr/local/lib or whatever the path is for
> libz and try to link it again.
> Also make sure that when you configured mapserver that you pointed it to
> the correct php source directory because zend_* styff is linked into php
> also.
> -Steve
> > > Bob,
> > > Check the definition of $(CC) there is a know bug on some platforms
> > > where CC= gcc gcc or CC= cc cc
> > > just edit the Makefile and remove the duplicate cc or gcc
> > > -Steve
> > > Bob Carr wrote:
> > > > Compiling Mapserver 3.6 seems to go fine until it enters the
> > > > mapscript/php3 directory, then exits with the following:
> > > > make.gnu[1]: Entering directory
> > > > `/usr/home/racarr/downloads/source/mapserver-3.6.0/mapscript/php3'
> > > > cc undef -I. -I.. -DPIC -fpic -O2 -Wall -DCOMPILE_DL=1 -DPHP4
> > > > -DUSE_WMS_LYR -DUSE_WMS -DUSE_POSTGIS -DUSE_GDAL -DUSE_OGR
> > > > -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_TIFF -DUSE_GD_PNG -DUSE_GD_JPEG
> > > > -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_JPEG
> > > > -I/usr/home/racarr/downloads/source/mapserver-3.6.0
> > > > -I/usr/local/include -I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H
> > > > -I/usr/local/pgsql/include
> > > > -I/usr/home/racarr/downloads/gdal-1.1.5/port
> > > > -I/usr/home/racarr/downloads/gdal-1.1.5/core
> > > > -I/usr/home/racarr/downloads/gdal-1.1.5/ogr
> > > > -I/usr/home/racarr/downloads/gdal-1.1.5/ogr/ogrsf_frmts
> > > > -I/usr/home/racarr/downloads/gdal-1.1.5/ogr/../port
> > > > -I/usr/home/racarr/downloads/source/proj-4.4.5/src
> > > > -I/usr/home/racarr/downloads/source/mapserver_3.3/jpeg-6b
> > > > -I/home/racarr/downloads/php-4.1.1
> > > > -I/home/racarr/downloads/php-4.1.1/dl
> > > > -I/home/racarr/downloads/php-4.1.1/main
> > > > -I/home/racarr/downloads/php-4.1.1/Zend
> > > > -I/home/racarr/downloads/php-4.1.1/include
> > > > -I/home/racarr/downloads/php-4.1.1/TSRM -c -o php_mapscript_util.o
> > > > php_mapscript_util.c
> > > > cc: cannot specify -o with -c or -S and multiple compilations
> > > > make.gnu[1]: *** [php_mapscript_util.o] Error 1
> > > > make.gnu[1]: Leaving directory
> > > > Triggering this seems to be lines #84 & #85 in the mapscript/php3/Makefile,
> > > > which reads:
> > > > 84 %.o: %.c php_mapscript_util.h php_mapscript.h
> > > > 85 $(CC) $(CFLAGS) -c -o $@ $<
> > > > Obviously, I'm stumped and will appreciate any assistance
> > In the mapscript/php3/Makefile I have the line
> > CC = gcc -undef -I. -I.. -DPIC -fpic
> > LD = gcc -Wl -Wl
> > Originally they both specified cc instead of gcc. I changed that. I've also
> > added a '-' to the 'undef' option, and now compilation proceeds a bit further,
> > but still fails with several 'undefined references' in php_mapscript.o
> > Here's an excerpt from the script file recorded.
> > cd mapscript/php3; /usr/bin/make.gnu; cd ../..
> > make.gnu[1]: Entering directory `/usr/home/racarr/downloads/source/mapserver-3.6.0/mapscript/php3'
> > gcc -Wl -Wl -o php_mapscript.so php_mapscript_util.o php_mapscript.o mapscript_i.o
> > -R/usr/home/racarr/downloads/source/mapserver_3.3/jpeg-6b -R/usr/local/lib -R/usr/local/include/lib
> > -R/usr/home/racarr/downloads/source/proj-4.4.5/src/.libs -R/usr/home/racarr/downloads/source/mapserver-3.6.0
> > -L/usr/home/racarr/downloads/source/mapserver-3.6.0 -lmap -L/usr/local/lib -lwwwxml -lxmltok -lxmlparse -lwwwinit
> > -lwwwapp -lwwwhtml -lwwwtelnet -lwwwnews -lwwwhttp -lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir -lwwwcache
> > -lwwwstream -lwwwmux -lwwwtrans -lwwwcore -lwwwutils -lmd5 -L/usr/local/pgsql/lib -lpq
> > -L/usr/home/racarr/downloads/gdal-1.1.5 -lgdal.1.1 -lgeotiff -lpng -lgrass5 -lz -lm -L/usr/local/lib -lm
> > -L/usr/home/racarr/downloads/source/proj-4.4.5/src/.libs -lproj -L/usr/local/include/lib -ltiff
> > -L/usr/home/racarr/downloads/source/mapserver_3.3/jpeg-6b -ljpeg -L/usr/local/lib -lfreetype -L/usr/local/lib -lpng
> > -lz -lgd -L/usr/local/lib -lgd -L/usr/home/racarr/downloads/source/mapserver_3.3/jpeg-6b -ljpeg -L/usr/local/lib
> > -lfreetype -L/usr/local/lib -lpng -lz -L/usr/home/racarr/downloads/source/mapserver_3.3/jpeg-6b -ljpeg -lm
> > /usr/home/racarr/downloads/gdal-1.1.5/ogr/ogrsf_frmts/ogrsf_frmts.a /usr/home/racarr/downloads/gdal-1.1.5/ogr/ogr.a
> > /usr/home/racarr/downloads/gdal-1.1.5/ogr/../port/cpl.a
> > /usr/local/lib/libwwwcore.so: warning: tmpnam() possibly used unsafely; consider using mkstemp()
> > /usr/local/lib/libwwwcore.so: warning: tempnam() possibly used unsafely; consider using mkstemp()
> > php_mapscript_util.o: In function `_phpms_report_mapserver_error':
> > php_mapscript_util.o(.text+0x33): undefined reference to `zend_error'
> > php_mapscript_util.o: In function `_phpms_fetch_handle2':
> > php_mapscript_util.o(.text+0x95): undefined reference to `zend_hash_find'
> > php_mapscript_util.o(.text+0xae): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0xc3): undefined reference to `_zend_list_find'
> > php_mapscript_util.o(.text+0xea): undefined reference to `zend_error'
> > php_mapscript_util.o: In function `_phpms_fetch_property_handle2':
> > php_mapscript_util.o(.text+0x154): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x178): undefined reference to `zend_hash_find'
> > php_mapscript_util.o(.text+0x19a): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x1b7): undefined reference to `_zend_list_find'
> > php_mapscript_util.o(.text+0x1e5): undefined reference to `zend_error'
> > php_mapscript_util.o: In function `_phpms_fetch_property_string':
> > php_mapscript_util.o(.text+0x258): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x27c): undefined reference to `zend_hash_find'
> > php_mapscript_util.o(.text+0x29e): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x2b5): undefined reference to `_convert_to_string'
> > php_mapscript_util.o: In function `_phpms_fetch_property_long':
> > php_mapscript_util.o(.text+0x30c): undefined reference to `zend_hash_find'
> > php_mapscript_util.o(.text+0x32e): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x344): undefined reference to `convert_to_long'
> > php_mapscript_util.o(.text+0x364): undefined reference to `zend_error'
> > php_mapscript_util.o: In function `_phpms_fetch_property_double':
> > php_mapscript_util.o(.text+0x3a4): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x3c4): undefined reference to `zend_hash_find'
> > php_mapscript_util.o(.text+0x3e6): undefined reference to `zend_error'
> > php_mapscript_util.o(.text+0x3f5): undefined reference to `convert_to_double'
> > bob carr
> > port washington, wisconsin
bob carr
More information about the MapServer-users
