[mapserver-users] abutters lists
    Lowell Filak
    lfilak at medinaco.org
    Wed Jun 19 09:19:44 PDT 2002
We have not gotten that far yet here, however we did look at it and we did not find a better solution than a tolerance because the relationship between polygon<->arc we used on coverages does not hold true in shapefiles. It's just a guess but I think this is what makes (last time I checked) an sde checkout lock the least-bounding-rectangle as opposed to an arcstorm checkout that locks features only. If you have other ideas we would definitely like to hear what you find.
Lowell F.
The following message was sent by "Kevin Flanders" <kevinflanders at attbi.com> on Tue, 18 Jun 2002 19:47:25 -0400.
> I am wondering about parcel map abutter's lists....I know that I can set the
> tolerance in the mapfile and find all parcels within a tolerance, but that
> is not exactly accurate.
> Has anyone created abutters tools out there?
> Kevin
More information about the MapServer-users
