[mapserver-users] MapScript file is blank
DebasishS at riskinc.com
Mon Mar 4 03:48:19 EST 2002
The mapscript.i file is blank in the nightly distribution under the java
directory.
thanks and regards
Debasish Sahu.
Senior Software Engineer
RMS India.
A-7,Sector-16
Noida-201301.
Uttar Pradesh.India.
Phone : +91-118-4511102
Fax : +91-118-4511109
Website : http://www.rmsinet.com
Sent by: To: steve.lime at dnr.state.mn.us
owner-mapserver-users at lists.g cc: mapserver-users at lists.gis.umn.edu,
is.umn.edu owner-mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] MapScript Java
03/04/02 10:45 AM
Can you provide a pre-built Win32 shared dll of MapScript like the Win32
binaries , that would be very helpful .
thanks and regards
Debasish Sahu.
RMS India.
A-7,Sector-16
Noida-201301.
"Steve Lime"
<steve.lime at dnr.state.mn.us> To:
<mapserver-users at lists.gis.umn.edu>
Sent by: cc:
owner-mapserver-users at lists.g Subject:
is.umn.edu
03/04/02 01:10 AM
I've cleaned up the MapServer header files and the Swig interface file so
that you can get a clean Java build without hacking the Swig output. I've
included a java directory and a basic Makefile in the CVS which should be
in tonites nightly. At the moment you'll need Swig (1.3.11 or higher) since
the version installed on the UMN machines doesn't support Java very well.
To build the java stuff...
1) cd mapscript/java
2) edit the Makefile to match your site (set location of java on your box
and cc/ld flags)
3) type 'make'
You're on your own for installation/use at the moment. More later on those
topics.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
