[mapserver-users] getDouble(): Symbol definition error. (UNITS):(7)
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 6 12:16:48 EST 2002
Ah! but you DID specify one that was incomplete, in that it did not have
4 numbers on it. Remove the tag completely or try numbers like
-73.530000 41.170000 -69.890000 42.950000
-Steve W.
Jim Palma wrote:
> Ah, that is the EXTENT command, which I left blank because I didn't really
> know how to figure it out. The manual says that "mapserver will extrapolate
> one if none is specified," but maybe that is not always the case? And just
> how do I figure out the extent of the map anyway?
> Jim
> Stephen Woodbridge wrote:
> > It usually means the problem occured on the prior line so check line 6,
> > what is it?
> > -Steve W.
