[mapserver-users] Mapserver and gdal
giorgio
giorgio19291 at inwind.it
Fri Mar 8 12:58:08 EST 2002
Hi all,
1) to permit mapserver load GRASS raster file I have compiled GDAL --with-libgrass and it look run normally: $gdalinfo /grassdata/spearfish/PERMANENT/cellhd/soils give me all information about map.
2) I have configured mapserver (3.5 and dev 3.6) --with-gdal and during compilation I have not observed errors and if I type ./mapserv -v in the mapserver directory the result is:
" MapServer version 3.6 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE"
It generally run normally on tiff images but if I try to load GRASS format it give me these errors:
GRASS: msDrawRaster(): Image handling error. Unrecognized or unsupported image format
I have tried also on gif file format and the result is: (my GD do not load gif images but gdal yes)
GIF: drawGIF(): Image handling error. GIF support is not available.
3) Is there a method to check if mapserv utilize effectively the libgdal??
And if not how I can force this to utilize gdal?
Thanks a lot Giorgio.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020308/8eb8359d/attachment.html
