[mapserver-users] compile php4 on debian with dbase (--with-dbase -> ignored)
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Mar 8 14:52:03 PST 2002
Chris,
I think you have to make sure you have the dbase libraries already
install on your system. Usually the --with-* options mean that you have
the libraries installed and that you want to add the code to php that
will call the installed libs.
Check to see if you have a php_dbase.so anywhere, if you do then you
might need to do a dl(/path/to/php_dbase.so"); if it is not configure in
the php.ini file.
I have RH and haven't used Debian so I could be wrong.
-Steve W.
Christoph Kuhn wrote:
> Hi!
> I'm trying to compile php4 with dbase on debian (testing). I found
> the PHP4-4.0.6 Debian-Sources and changed the debian/rules file
> inserting the --with-dbase option.
> It compiled without an only message about dbase. If I call
> phpinfo.php, it says that php is compiled '--with-dbase' but there
> is no dbase-support at all.
> ./configure --help -> nothing about dbase!!!
> (It was the same behaviour with the newest debian-php-sources).
> How can I compile PHP4 with dbase?
> Thank you!
> chris
More information about the MapServer-users
