Hi all I try to change the map file parameter QUERYMAP SIZE via URL with ...&mode=itemquerymap&map_querymap_size=600+600&... and MapServer 3.5 but ist doesn't work. MapServer hangsup until Server timeout. What changed from 3.4 to 3.5, because the same routine work fine with 3.4?? Regards Horst
